Suzuki AN400 Burgman/Skywave story
Messaggioda suzukista » sab lug 21, 2007 12:29 am
Being Suzuki's largest scooter at the time, the AN400 appeared to the Suzuki 1998 year's model range. In the western world the AN family has been known as Burgman but Skywave in Japan. On this page I call the model AN400 Burgman, unless the picture presents a Skyway 400, sold at the Japanese home market.
1998 Suzuki year code: W
Model name: AN400W Burgman/Skywave
Initial frame number: CK41A-100001
Engine type: K415
AN 400 Skywave 1998
Overall Length: 2 260 mm (89.0 in)
Overall Width: 765 mm (30.1 in)
Overall Height: 1 365 mm (53.7 in)
Seat Height: 695 mm (27.4 in)
Wheelbase: 1,590 mm (62.6 in)
Ground Clearance: 120 mm (4.7 in)
Dry weight: 174 kg (383 lbs)
Engine type: Water-cooled 385 cc SOHC, 4 valves, single cylinder, variomatic transmission.
32 hp (24 kW)/ 7.500 rpm, 32 Nm (3,3 kg-m/ 6.000 rpm.
1999 Suzuki year code: X
Model name: AN400X Burgman/Skywave
Colors available: Red, Blue, Black, Silver
AN 400 Skywave 1999
2000 Suzuki year code: Y
Model name: AN400Y Burgman/Skywave
Colors available: Maroon, Blue, Black, Silver, Gold, Ice Blue
AN 400 Burgman 2000
2001 Suzuki year code: K1
The AN400 was revisited for 2001. The frame and the design were new. Nevertheless, the specifications of the bike remained the same.
Internal model code: CK42A
Initial frame number: CK42A-10
Engine type: K415
Colors available: Blue, White, Silver
AN 400 Burgman 2001
2002 Suzuki year code: K2
Colors available: Maroon, Blue, Silver, White
AN 400 Burgman 2002
Wheelbase: 1,590 mm (62.2 in)
Ground Clearance: 125 mm (4.9 in)
Dry Weight: 179 kg (394 lbs)
Engine type: Water-cooled 385 cc SOHC, 4 valves. Fuel injection, single cylinder, variomatic transmission.32 hp (23,5 kW)/ 7.600 rpm, 32 Nm/ 6.000 rpm.
AN 400 Burgman Martini Racing
Engine type: Water-cooled 385 cc SOHC, 4 valves. Fuel injection, single cylinder,variomatic transmission.32 hp (23,5 kW)/ 7.600 rpm, 32 Nm/ 6.000 rm.
2003 Suzuki year code: K3
From beginning of the 2003 year's model the AN400 has electric fuel injection like its big brother, AN600 Burgman — as well as 14 other Suzuki motorcycle models in 2003. In Japan, where the model is called Skywave 400 (BC-CK43A), a Limited Edition model was also available in Pearl Novelty Black / Variable Silver Metallic (LT3).
Colors available: Silver, Blue, White, Black/Silver.
AN 400 Burgman 2003
2004 Suzuki year code: K4
New features: Adjustable oil change indicator light - can be preset from 300 miles to 3,600 miles in 300 mile increments. Improved operation of front storage compartment covers.
Colors: Silver, Blue.
AN 400 Burgman 2004
Overall Width: 760 mm (29.9 in)
Overall Height: 1 375 mm (54.1 in)
Dry Weight: 184 kg (405 lbs)
32 hp (23,5 kW)/ 7,600 rpm, 32 Nm/ 6,000 rpm.
2005 Suzuki year code: K5
AN 400 Burgman 2005
AN 400 Burgman Type S 2005
Overall Length: 2,260 mm (89.0 in)
Overall Height: 1,375 mm (54.1 in)
Ground Clearance: 125mm (4.9 in)
Wheelbase: 1,590mm (62.6 in)
2006 Suzuki year code: K6
New features: Stylish bodywork with dual multi-reflector headlights, flush-mounted front turn signals, and large combination taillight/brake designed for strength and rigidity
The AN400 Type S (Skywave in Japan, Burgman in the West) is a sportier version of the model with similar machinery but offered with shortened smoke-finished windscreen, Chrome-plated handlebar; handlebar cover and rear-view mirrors, Aluminum rear spoiler mounted behind passenger seat, Black wheels and White instrument panel.
Colors: White, Blue, Black.
AN 400 Burgman Type S 2006
Overall Length: 2,270 mm (89.4 in)
Overall Height: 1,225 mm (48.2 in)
Seat Height: 710 mm (28.0 in)
Dry Weight: 200 kg (440 lbs)
32 hp (23,5 kW)/ 7,500 rpm, 32 Nm/ 6,000 rpm.
2007 Suzuki year code: K7
The 2007-year's model of the AN400 has got all-new headlights, bodywork and tailights. All new instrument panel with analog speedometer and tachometer combined with LCD odometer, twin tripmeters, clock and all new average fuel consumption readout. New larger windshield for increased rider comfort and creates a smooth flow of air over the rider. New larger 62 liter under-seat storage compartment. New oval section exhaust system now meets Euro 3 emission regulations with a catalyzer and oxygen sensor. New larger 14 inch front wheel combined with new dual hydraulic disc brakes up front. New liquid-cooled, 399cc DOHC 4-valve engine.
The AN400 Type S (Skywave in Japan, Burgman in the West) is a sportier looking model version with similar machinery but offered with shortened smoke-finished windscreen, Chrome-plated handlebar; handlebar cover and rear-view mirrors, Aluminum rear spoiler mounted behind passenger seat, Black wheels and White instrument panel.
Colors: White, Gray, Blue, Black.
AN 400 Burgman 2007
Overall Height: 1,385 mm (54.5 in)
Engine type: Water-cooled 385 cc DOHC, 4 valves. Fuel injection, single cylinder, variomatic transmission.
32 hp (23,5 kW)/ 7,600 rpm, 34 Nm/ 6,000 rpm.
AN 400 Skywave Type S 2007
Engine type: Water-cooled 399 cc DOHC, 4 valves. Fuel injection, single cylinder, variomatic transmission.
32 hp (23,5 kW)/ 7,500 rpm, 34 Nm/ 6,000 rpm.
Ultima modifica di suzukista il dom lug 22, 2007 12:10 am, modificato 1 volta in totale.
suzukista
Messaggioda opb75 » sab lug 21, 2007 12:34 am
secondo me il più bello rimane quello del 2000.....
opb75
Messaggioda Nheo » sab lug 21, 2007 10:43 am
opb75 ha scritto:secondo me il più bello rimane quello del 2000.....
...secondo me...quello del 2001/02 ....e non sono di parte..!!! :D :D
Scherzi a parte, ci sono delle cosette che non ho capito...
1998: 32 hp (24 kW)/ 7.500 rpm, 32 Nm (3,3 kg-m/ 6.000 rpm.
1999: 32 hp (24 kW)/ 7.500 rpm, 32 Nm (3,3 kg-m/ 6.000 rpm.
2000: 32 hp (24 kW)/ 7.500 rpm, 32 Nm (3,3 kg-m/ 6.000 rpm.
2001: 32 hp (24 kW)/ 7.500 rpm, 32 Nm (3,3 kg-m/ 6.000 rpm.
2002: 32 hp (23,5 kW)/ 7.600 rpm, 32 Nm/ 6.000 rpm.
M.Rac: 32 hp (23,5 kW)/ 7.600 rpm, 32 Nm/ 6.000 rm.
2003: 32 hp (23,5 kW)/ 7.600 rpm, 32 Nm/ 6.000 rpm.
2004: 32 hp (23,5 kW)/ 7,600 rpm, 32 Nm/ 6,000 rpm.
2005: 32 hp (23,5 kW)/ 7,600 rpm, 32 Nm/ 6,000 rpm.
2006: 32 hp (23,5 kW)/ 7,500 rpm, 32 Nm/ 6,000 rpm.
2007: 32 hp (23,5 kW)/ 7,600 rpm, 34 Nm/ 6,000 rpm.
K7: 32 hp (23,5 kW)/ 7,500 rpm, 34 Nm/ 6,000 rpm
il primo modello ha 32hp per 24Kw a 7500 giri, a partire dal mio modello (2002) i Kw diventano 23,5 (mortacci loro!!), ma ho sempre 32hp pur guadagnando 100 giri (7600)... Peggio (sempre sulla carta) solo il K6 che ha stesdsa cavalleria e anche 100 rpm in meno...
Il K7 perde il mezzo kilowatt, perde i 100 giri, guadagna 14cc e ha sempre 32 hp? Non siamo bassini?..Ma la "concorrenza" come sta messa a cavalleria?
Nheo
Nome di battesimo: maglitVE
Modello scooter o moto: B400 K2 Argento
Messaggioda rod » sab lug 21, 2007 11:46 am
Non pensavo esistesse un ciccino K2 stile "Martini Racing"! :D
Bello, bello... ;)
Messaggioda Knarf » sab lug 21, 2007 1:13 pm
Bellissimo topic Suzu. :ok:
Ci voleva proprio una raccolta per chi, me compreso, essendosi non da molto avvicinato al Burgman400 non conosce precisamente tutti i modelli.
Veramente bravo :clap: :clap:
Messaggioda rod » sab lug 21, 2007 6:10 pm
Knarf ha scritto:Bellissimo topic Suzu. :ok:
Quoto :D :D :D , grazie al tuo topic Suzu ora so anche che cacchio di differenza c'è tra il K1 ed il K2! ;)
Messaggioda opb75 » sab lug 21, 2007 6:19 pm
scusate ma l'AN 400 Skywave Type S 2007 è commercializzato in europa??
opb75
Messaggioda bruno » sab lug 21, 2007 9:02 pm
.....Il K7 perde il mezzo kilowatt, perde i 100 giri, guadagna 14cc e ha sempre 32 hp? Non siamo bassini?..Ma la "concorrenza" come sta messa a cavalleria?
ti faccio un esempio dell'X8 400 i.e.
399 cc 34 hp = 25 Kw (è il limite per la patente A) poi la potenza espressa alla ruota(che è quella che conta) non la sò :(
P.S.
Il K7 come linea è il migliore
bruno
Nome di battesimo: il mio
Messaggioda suzukista » sab lug 21, 2007 11:55 pm
opb75 ha scritto:scusate ma l'AN 400 Skywave Type S 2007 è commercializzato in europa??
Sicuramente in italia :nono: .. e penso anche in Europa..
suzukista
Messaggioda Playbeppe » dom lug 22, 2007 5:02 pm
Molto bello questo topic riassuntivo di tutte le versioni con relativi dati tecnici, anche se qualche dato non è corretto....
alcuni che mi son balzati all'occhio:
-il K7 ha 25kw (34cv) e non 23,5kw come riportato
-nel K7 versione AN (e non type S) viene riportata una cilindrata si 385cc contro quella reale di 399cc
-di questo non son sicuro, ma il peso a secco del K6 mi risulta essere inferiore a quello riportato di 200kg
Altre cose non ne ho viste.
Playbeppe
Messaggioda Bond » dom lug 22, 2007 11:10 pm
dopo le varie correzioni, sarebbe meglio spostare questo utile Topic nella sezione Faq.. ;)
Bond
Messaggioda Pascal » lun lug 23, 2007 1:14 am
Prima che si perda il messaggio copio nella sezione FAQ. Il lavoro sporco lo lascio a knarf :lol:
Amministratore
Amministratore
Messaggioda Knarf » lun lug 23, 2007 1:33 am
:DP :68:
Si continua :arrow: qui
Grazie ancora Suzu, ottimo topic davvero :ok:
